STM32 Inaccurate PWM Freq
‎2021-06-19 09:30 PM
I have the Nucleo - STM32F446RE board and have been trying to work with the PWM (using CubeMX) on it for Motor Control. But for some reason I was getting 32.8Khz whenever I set it for 32Khz (while SYSCLK was 180Mhz). I checked my calculations but to no avail. Finally I realized that when I set it to 84Mhz, I got the accurate 32Khz frequency I wanted. Upon further inspection if I kept the SYSCLK as 84, APB2 prescaler as /2 and *2 again for the APB2 timers, the problem returned. I realized that it may not have been about just the SYSCLK but the prescalers too. A /2 *2 configuration caused the 32.8Khz and a /1 *1 configuration resolved it (for 84 Mhz), but I can't do the same for 180Mhz as the clock after the first prescaler is supplied to APB2 peripherals and has a max of 90Mhz, so it can only work with a /2. This board is actually an upgrade to another M4 board I ran on 80Mhz and found to be insufficient for my use so I was looking forward to the 180Mhz. Is there any way I can solve this and get both, 180Mhz and accurate PWM? I have pasted the code and clock tab below if it can help.
#include "main.h"
TIM_HandleTypeDef htim2;
TIM_HandleTypeDef htim5;
static void MX_TIM5_Init(void);
static void MX_TIM2_Init(void);
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_TIM5_Init();
MX_TIM2_Init();
/* USER CODE BEGIN 2 */
HAL_TIM_PWM_Start(&htim5,TIM_CHANNEL_3);
HAL_TIM_PWM_Start(&htim2,TIM_CHANNEL_1);
/* USER CODE END 2 */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 84;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 2;
RCC_OscInitStruct.PLL.PLLR = 2;
Error_Handler();
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM2_Init 0 */
/* USER CODE END TIM2_Init 0 */
TIM_ClockConfigTypeDef sClockSourceConfig = {0};
TIM_MasterConfigTypeDef sMasterConfig = {0};
TIM_OC_InitTypeDef sConfigOC = {0};
/* USER CODE BEGIN TIM2_Init 1 */
/* USER CODE END TIM2_Init 1 */
htim2.Instance = TIM2;
htim2.Init.Prescaler = 0;
htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
htim2.Init.Period = 10000-1;
htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_ENABLE;
if (HAL_TIM_Base_Init(&htim2) != HAL_OK)
Error_Handler();
sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL;
if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK)
Error_Handler();
if (HAL_TIM_PWM_Init(&htim2) != HAL_OK)
Error_Handler();
if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.OCMode = TIM_OCMODE_PWM1;
sConfigOC.Pulse = 2000;
sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
sConfigOC.OCFastMode = TIM_OCFAST_ENABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim2, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM2_Init 2 */
/* USER CODE END TIM2_Init 2 */
HAL_TIM_MspPostInit(&htim2);
* @brief TIM5 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN TIM5_Init 0 */
/* USER CODE END TIM5_Init 0 */
/* USER CODE BEGIN TIM5_Init 1 */
/* USER CODE END TIM5_Init 1 */
htim5.Instance = TIM5;
htim5.Init.Prescaler = 0;
htim5.Init.CounterMode = TIM_COUNTERMODE_UP;
htim5.Init.Period = 5364;
htim5.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
htim5.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
if (HAL_TIM_PWM_Init(&htim5) != HAL_OK)
Error_Handler();
if (HAL_TIMEx_MasterConfigSynchronization(&htim5, &sMasterConfig) != HAL_OK)
Error_Handler();
sConfigOC.Pulse = 2182;
sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
if (HAL_TIM_PWM_ConfigChannel(&htim5, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN TIM5_Init 2 */
/* USER CODE END TIM5_Init 2 */
HAL_TIM_MspPostInit(&htim5);
* @brief GPIO Initialization Function
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin : B1_Pin */
GPIO_InitStruct.Pin = B1_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
STM32F4 Series
TIM
‎2021-06-19 11:19 PM
HSI is unprecise and PLL influences it - see footnote under the HSI parameters table in the latest datasheet.
‎2021-06-20 02:24 AM
The Period value needs to be encoded as N-1
84,000,000 / 2183 = 38479.157
84,000,000/ 32000 = 2625
htim5.Init.Period = 2625-1;
sConfigOC.Pulse = 1312; or 1313 would be approximately 50/50 duty
‎2021-06-20 03:21 AM
I dont understand you example code (5364 result to ~15k), maybe your setup have some fail .
But when you need perfect freq, you need HSE or thermal corrected calibrate HSI table.
Simple calculation if error HSI is +3% then your 32k changes to 32,96k
‎2021-06-20 10:02 PM
Yes the 5364 was just me tying out different values to check if the problem was at that specific range of frequency, sorry I forgot to update. As you all suggested I fixed the problem by using HSE and and am now getting the desired 32 Khz. Thanks
‎2021-07-17 08:29 AM
The 90 MHz limit is for APB2 peripheral clock (PCLK2). For APB2 timer clock the maximum is 180 MHz.
