SPL2LL converter error message
‎2024-05-13 8:51 AM
Dear all,
I am trying to convert the SPL to LL using the SPL2LL converter. After pressing the migrate button, I got the message below. Please help. Is it the problem that I chose the wrong directory? I chose the directory where the main.c file is located (./). All the others' ./apps are stored in /app.
- Labels:
Bug-report
STM32F2 Series
‎2024-05-13 10:07 AM
I don't know. Try simpler pathing, and perhaps without spaces or special characters.
‎2024-05-13 10:22 AM
@Tesla DeLorean wrote:without spaces or special characters.
^^^^ This! Always! ^^^^
@khwuuk See:
https://www.avrfreaks.net/s/topic/a5C3l000000UY8vEAG/t145039?comment=P-1182240
‎2024-05-14 1:26 AM
Dear Tesla and Andrew,
I removed the space, and no special characters were on the path. There are still error messages.
Is it the problem of Strawberry Perl? I installed ActiveState Perl and Strawberry Perl at the same.
‎2024-05-14 3:12 AM
After installing the older version of Perl, I can run the SPL2LL converter now.
Thank you so much.
‎2024-05-14 3:45 AM
Thanks for updating - please mark that as the solution.
Might also be helpful to mention which version
‎2024-05-14 4:43 AM - edited ‎2024-05-14 6:11 AM
I am using the SPL2LL converter's GUI interface. Does the source file path mean the location of the main.c? Or do I need to group all the .c .h files into one folder? Please give me some hints about it.
Thank you very much.
‎2024-05-14 5:01 AM - edited ‎2024-05-14 5:12 AM
I've never used it, so I have no idea.
However, the errors you posted in the OP don't seem to be about failure to find your source files - they look more like errors in the utility itself.
EDIT:
You didn't answer the question of what Perl version you are using.
You should probably also state what platform you're running on, version, etc ...
‎2024-05-14 5:06 AM
@STTwo-32 can someone review the status of this tool and what dependencies it has. Perhaps doing a 2024 refresh with current expectations and document them. Thanks.
‎2024-05-15 1:45 AM - edited ‎2024-05-25 3:07 PM
Dear Andrew,
I used the old Perl version. The higher version is not supported.
