2011-09-02 12:34 AM
Hello
I am using Stm32f107 controller for my spi application to read nor flash but even after using the sample code given in the firmware library i m not able to drive my Spi as for confirmation when i tried to check the Clock (i.e. spi clock ) on the oscilloscope i am not seeing anything..pls help me i m i m totally stuck.... #flash-memory #spi #stm322011-09-02 10:35 AM
Well you probably need to post enough of the initialization, and SPI code, so forum members are not totally clueless to what you are doing, and why it might not be working for you.
