stock2
Read all pins in 1 port simultaneously
  • April 11, 2014
  • 4 replies
  • 1113 views
Posted on April 11, 2014 at 15:27
I wonder how to read all port simultaneously such as GPIOA0 up to GPIOA7
or the equivalent of arduino codes
DDRA = B00000000;   // sets Arduino Mega Digital pins 22(PORTA0) to 29(PORTA7) as inputs
allBus = PINA; //read all PIN bit state
#ports #pins
    waclawek.jan
    Posted on April 11, 2014 at 15:32
    GPIOA->MODER = 0;
    allbus = GPIOA->IDR;
    stock2
    stock2Author
    Posted on April 11, 2014 at 15:36
    Thanks I will try the codes right away
    Andrew Neil
    Posted on April 11, 2014 at 21:30
    I think you are confusing pins  with ports?
    As described, you can read all the pins  of a port simultaneously; but you can't read multiple ports  simultaneously.
    stock2
    stock2Author
    Posted on April 12, 2014 at 04:27
    Yes, you are correct I mean all pins in one port, problem solved.
