Problem with UART Example on Nucleo-F746ZG
‎2017-09-28 7:47 AM
Hello everyone
Yesterday i buy a Nucleo-F746ZG, i installed SW4STM32, ST-LINK/V2 Drivers and
examples, first of all i try the Demonstration firmware and all was good.Finally i decide to try the Uart Example and here start the problems, i download on the board the firmware using SW4STM32 and the usb cable, then i try to read the messages with several terminals (Termite, Hyperterminal, Putty) but i not see any message(i also try to reset it using push button on the board but nothing), using the oscilloscope on the TX and RX lines on the CN5 connector i see a fixed 3.3 V.
I make something wrong? any idea about the problem?
Thank's for the attention and for the help
#nucleo-f746 #example #uart #problemSolved! Go to Solution.
STM32F7 Series
UART-USART
‎2017-09-28 10:53 AM
Demo .HEX file here
https://community.st.com/0D70X000006T0kmSAC
,Up vote any posts that you find helpful, it shows what's working..
‎2017-09-28 8:31 AM
Apparently, which example specifically are you compiling, have you used the debugger and stepped the code, do you have the right baud rate and COM port?
The USART/VCP works on the boards here.
Demo .HEX file here
‎2017-09-29 1:51 AM
Thank you Very much for your answer, with your code work correctly, you have the source code of that program ? because i have the same problem on another firmware, what was the problem ?
‎2017-09-29 7:40 AM
I find the problem, was missing the file syscalls.c, adding it the example work, i think that this problem happens using the eclipse IDE SW4STM32
‎2019-05-09 9:27 PM
Thank you Mohamed.
I have a same issue but I resolved by your answer.
Please copy syscall.c to SW4STM32 dirctory if anybody have the same issue.
I did it like a following.
copy STM32F746ZG-Nucleo\Applications\USB_Host\HID_Standalone\SW4STM32\syscall.c ==> STM32F746ZG-Nucleo\Examples\UART\UART_Printf\SW4STM32\STM32746ZG_Nucleo\
If you use odd for parity bit, you will see strange character.
UartHandle.Init.Parity = UART_PARITY_ODD;
result) * T??é³¶n?h? suå¨ ?s?壹y?** 둇 一b?? p侄n廳 ?nè¾›æ—n 剃 ??襤RT?
I've changed parity bit to none and it show it correctly.
UartHandle.Init.Parity = UART_PARITY_NONE;
result) UART Printf Example: retarget the C library printf function to the UART
** Test finished successfully. **
