NO FMC_SDNCAS alternate function info in
sheng yang
I want to design a baord with stm32h7b0zbt6 with extranal sdram chip W9825G6KH-6. I get PG15 with FMC_SDNCAS alt func in datasheet as below:
But when I looked the PG15 alt func config I get as below info, I could not found an alternate function number for FMC_SDNCAS here ?? why they are not consistent ?
11 REPLIES 11
SofLit
Most probably it's a miss in table 14. By analogy with STM32H743 PG15 has FMC_SDNCAS alternate function.
The internal ticket 178406 has been submitted to confirm and fix the issue.
I will keep you informed for any feedback.
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
Tks ,waiting for your reply.
Update: issue confirmed.
The internal ticket 178406 has been summitted to fix this issue.
Thank you.
What's the tentative solution? Fix the table? Hiding stuff in internal tickets doesn't help visibility for users.
Use AF12 for PG15 and PG14 ??
PG14 has a FMC_Ax assignment, didn't check others.
The doubt was about PG15 in table 14. Nothing about PG14.
Moreover, CubeMx has already the correct alternate function FMC_SDNCAS on PG15:
The the only stuff to fix is the table 14 in the datasheet: PG15 should have FMC_SDNCAS alternate function on it.
Because I didn't use CubeMX, is the AF num is AF12 as FMC_SDNCAS with PG15?
Yes it's mapped on PG15/AF12
I'm say the in the OP's top post, that both PG14 (FMC_A25) and PG15 (FMC_SDNCAS) fail to show settings in the AF Table. The RM is the controlling document, so it's important it's correct(ed).
PG12, PG13, PG14, and PG15 are not correctly documented
