I2C not working with STM32F103C6 and STM32F103C8
RShiv.1
we have been trying to get the I2C up on both the controller and no responses from anyone the cubeMx issue if I2C is really a problem..Kindly respond as we are trying to get I2C up ..
requesting the experience forum experts to respond.
Ravi
63 REPLIES 63
RShiv.1
attached is the code where I am doing all measurement code..also..not getting the value...basically get ready flag itself fails...
regards
Ravi
AScha.3
Chief III
from the ds you posted, i cannot say, what to do better.
now lets stop  to play blind cow . :)
so look, what drivers exist and learn/copy from them :
here sensirion gives driver for their sensor:
https://github.com/Sensirion/embedded-i2c-scd30
and many others...(also in c++, rust etc.)
https://github.com/paulvha/scd30
https://github.com/sparkfun/SparkFun_SCD30_Arduino_Library
https://github.com/RequestForCoffee/scd30
https://github.com/adafruit/Adafruit_SCD30
https://github.com/Seeed-Studio/Seeed_SCD30
https://github.com/watterott/CO2-Ampel
https://github.com/sinewave-ee/scd30-rs
the driver by sensirion should show you, what to do.
RShiv.1
Finally worked!!!!!!!!!!!!!
I was actually referring to the first link only last time when I told you about the pattern..
as planned I only replaced/used the same flow...just replace and got working on STM32F103C8..attached is the zip file...this will also work for C6
RShiv.1
Let me be honest in accepting that I am beginner to STM environment and its IDE...but definitely not the experience..In the current domain I was trying to help out from what my team had done.
Agree that name of the file did not change as we were trying out different projects at same time..
sorry if this has caused a concern and would rectify the same...the reason request to help us is raised so that there might not be a single solution to a problem.and would like to take help from those who are experienced ...will keep up the way forum wants ..Thanks
regards
Ravi
