I2C Communication Protocol
dhirrajsharma
Visitor
I am currently working on I2C communication with the STM32G030F6P6 microcontroller and developing a library for slave mode. I encountered an issue where, after the master transmits a command, the slave receives and processes the data, responding accordingly. However, when the command doesn't match the expected input and the master sends a receive request, clock stretching occurs. If anyone has insights on how to handle or resolve this, I would appreciate your suggestions
1 REPLY 1
Imen.D
Hello @dhirrajsharma
Did you check the Errata sheet related to your device?
Try enable the I2C listen mode to handle address match events.
Imen
