I would like to know if there is a way to setup IPCC in Cube MX 6.3
‎2022-09-07 6:01 PM
In UM1718, it states that IPCC is only used for the STM32MP1 series.
I understand that I need to update the version that I'm using however, I do not want to loose and have to restart again for our project.
Furthermore, I've tried to use the H747 and other dual core MCU's but, only the series MP1 indicates the IPCC.
I need to communicate and share data from CM7-CM4 and visa versa.
- is there a way to setup IPCC in Cube MX 6.3 or do I need to use STM32 Cube H?
If I can use the current version I have, how do I establish a communication link between cores in Cube MX? Please recommend the documentation that I would need.
AHB, Simplex Communication I've studied but, I have not solidified the setup.
Thanks,
Hiram
- Labels:
STM32H7 Series
‎2022-09-12 3:19 AM
Hi @Hiram Hyman​ ,
You may find answers to your questions in this article STM32H7 Dual-Core: How to communicate between CM4 & CM7?
-Amel
‎2022-09-07 11:15 PM
IPCC is a hardware block that is included in a few STM32s so far: STM32MP1, STM32WB and STM32WL5. Since the STM32H747 does not contain an IPCC, inter-processor communication must be handled in the classic way via software.
Does it answer your question?
/Peter
‎2022-09-08 3:40 AM
Hi Mr. Bensch,
Yes it does to a certain degree. Although, where might I find more about the classic way? I noticed that OpenAMP is forced for use so, perhaps this is the route that I must use. I'll check on the ST website for information.
Thanks,
Hiram
‎2022-09-12 3:19 AM
Hi @Hiram Hyman​ ,
-Amel
‎2022-09-13 3:20 AM
It was a great help for the needed clarification.
Thanks,
Hiram
‎2022-10-05 4:19 PM
It's a shame that ST's article does not even mention the most obvious, easiest, universal and efficient way to do it...
https://github.com/MaJerle/stm32h7-dual-core-inter-cpu-async-communication
