I want to use CubeMX examples with CubeIde
2021-03-22 6:56 AM
I just started using CubeIde but using Cube examples gives a lot errors. Should I just copy all the .H and .C files (from where?) somewhere or is there a better way.
I have 32H750 and 32F746 Discovery boards and my own boards.
- Labels:
STM32H7 series
2021-03-22 7:01 AM
Hello @LMI2
As I understood, with a simple project generated using the Examples provided on CubeMX, you get errors, right?
Could you please share more details if not the case, and specially the example used with which you encountered errors?
Thanks, Khouloud
2021-03-22 1:12 PM
Thank you for your answer. I was lucky today and could combile one project. I tried to be quick last time and of course got problems. I think my problems come from unfamilar environment. Keil was much easier to use. Eclipse is sometimes total.
Leif M
