Hello, Is there any evaluation board compatible with STM32F302RCT6. I don't need to use the pinout, I just need to upload a ready code written for STM32F302RCT6 and use the evaluation board as emulator.
CAkka.1
The code uses STM32F3xx_HAL_Driver.
Probably as close as you can get from ST, if you need more than 64KB FLASH you could always have someone remove the R8 and place the RC (check if the die is the same first)
https://www.st.com/en/evaluation-tools/nucleo-f302r8.html
