I am using a STM32f7 as a SPI master and STM32F0 as SPI slave. When I am Running Both MCU at 48 MHz then transmission and reception both are working well but when I am running STM32F7 at 216 MHz then its not working.
imran.aftab
Please help me.
My code
SPI Master Code----------------------
Initialization
/* SPI4 init function */
void MX_SPI4_Init(void)
 hspi4.Instance = SPI4;
 hspi4.Init.Mode = SPI_MODE_MASTER;
 hspi4.Init.Direction = SPI_DIRECTION_2LINES;
 hspi4.Init.DataSize = SPI_DATASIZE_16BIT;
 hspi4.Init.CLKPolarity = SPI_POLARITY_LOW;
 hspi4.Init.CLKPhase = SPI_PHASE_2EDGE;
 hspi4.Init.NSS = SPI_NSS_SOFT;
 hspi4.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
 hspi4.Init.FirstBit = SPI_FIRSTBIT_MSB;
 hspi4.Init.TIMode = SPI_TIMODE_DISABLE;
 hspi4.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
 hspi4.Init.CRCPolynomial = 7;
 hspi4.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
 hspi4.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
 if (HAL_SPI_Init(&hspi4) != HAL_OK)
  Error_Handler();
void HAL_SPI_MspInit(SPI_HandleTypeDef* spiHandle)
 if(spiHandle->Instance==SPI4)
 /* USER CODE BEGIN SPI4_MspInit 0 */
 /* USER CODE END SPI4_MspInit 0 */
  /* SPI4 clock enable */
  __HAL_RCC_SPI4_CLK_ENABLE();
  __HAL_RCC_GPIOE_CLK_ENABLE();
  /**SPI4 GPIO Configuration
  PE2   ------> SPI4_SCK
  PE5   ------> SPI4_MISO
  PE6   ------> SPI4_MOSI
  GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_5|GPIO_PIN_6;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF5_SPI4;
  HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
 /* USER CODE BEGIN SPI4_MspInit 1 */
 /* USER CODE END SPI4_MspInit 1 */
Main code
 while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
HAL_Delay(4000);
spiDataTx[0]++;
HAL_GPIO_WritePin(GPIOF, GPIO_PIN_4, GPIO_PIN_RESET);
HAL_SPI_Transmit(&hspi4, (uint8_t *)spiDataTx, 1, HAL_MAX_DELAY);
while(HAL_SPI_GetState(&hspi4)!=HAL_SPI_STATE_READY){}
HAL_SPI_Receive(&hspi4, (uint8_t *)spiDataRx, 1, HAL_MAX_DELAY);
HAL_GPIO_WritePin(GPIOF, GPIO_PIN_4, GPIO_PIN_SET);
//HAL_SPI_FlushRxFifo(&hspi4);
 /* USER CODE END 3 */
Slave code-----------------
Initialization
/* SPI2 init function */
void MX_SPI2_Init(void)
 hspi2.Instance = SPI2;
 hspi2.Init.Mode = SPI_MODE_SLAVE;
 hspi2.Init.Direction = SPI_DIRECTION_2LINES;
 hspi2.Init.DataSize = SPI_DATASIZE_16BIT;
 hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
 hspi2.Init.CLKPhase = SPI_PHASE_2EDGE;
 hspi2.Init.NSS = SPI_NSS_HARD_INPUT;
 hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
 hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
 hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
 hspi2.Init.CRCPolynomial = 7;
 hspi2.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
 hspi2.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
 if (HAL_SPI_Init(&hspi2) != HAL_OK)
  Error_Handler();
 if(spiHandle->Instance==SPI2)
 /* USER CODE BEGIN SPI2_MspInit 0 */
 /* USER CODE END SPI2_MspInit 0 */
  /* SPI2 clock enable */
  __HAL_RCC_SPI2_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /**SPI2 GPIO Configuration
  PB12  ------> SPI2_NSS
  PB13  ------> SPI2_SCK
  PB14  ------> SPI2_MISO
  PB15  ------> SPI2_MOSI
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Alternate = GPIO_AF0_SPI2;
  /* SPI2 interrupt Init */
  HAL_NVIC_SetPriority(SPI2_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(SPI2_IRQn);
 /* USER CODE BEGIN SPI2_MspInit 1 */
 /* USER CODE END SPI2_MspInit 1 */
main code-------------------
 MX_GPIO_Init();
 MX_SPI2_Init();
 /* USER CODE BEGIN 2 */
HAL_SPI_Receive_IT(&hspi2, (uint8_t *)spiDataRx, 1);
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
if(spiRxStatus){
HAL_SPI_Transmit(&hspi2, (uint8_t *)spiDataRx, 1, HAL_MAX_DELAY);
spiRxStatus=0;
SPI Rx callback-------------------
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi)
 /* Prevent unused argument(s) compilation warning */
 UNUSED(hspi);
spiRxStatus=1;
 /* NOTE : This function should not be modified, when the callback is needed,
      the HAL_SPI_RxCpltCallback should be implemented in the user file
12 REPLIES 12
I tried by giving delay too but its not working
Not working means
I am sending a character from master to slave and and the same character back to master.
When I am only sending character master to salve its working properly.
And when I am sending back the same data then slave even not receiving data but sometime it receives. But its never returning data to master.
But the same code when I run the master also at 48 MHz then it works perfectly.
If you insert delays between NSS edges and SPI transmission, and slow down the SPI clock at master, the waveform should be the same as with the master clocked at slower clock, i.e. indistinguishable by the slave. In other words, in that case the slave has no reason to behave differently.
You should observe the signals using logic analyzer, at both situations, and compare.
And when I am only sending data from slave to master then master is receiving the previous data even at 48 MHz
For example Initially my slave rx buffer showing ff which I have not sent even and when I am sending data from slave take a example 2 then hen here at master its showing 0 and when I am sending next data 3 then its receiving 2 and so on master is receiving previous data which slave sent.
