How to use serial wire debug pins after programming the stm32
‎2022-10-07 8:32 AM
I am using the serial wire debug SWDIO and SWCLK on PA13 and PA14 to program an stm32g031. Can I use these pin after the debug? If yes, do I have to modify some dedicated register (in addition to the GPIO registers) to use thiese pins as GPIO?
DEBUG
STM32G0 Series
‎2022-10-07 9:16 AM
Yes.
In 'G0, AFAIK, no.
Note, that if you also use the NRST pin as GPIO, the chip can't be programmed anymore.
‎2022-10-07 10:01 AM
I think the trick with the G0/NRST would be to have a) some dwell time between start-up and reconfiguring the pins, or b) some use case controlled method of resetting or deconfiguring pins, say via a command on serial port.
Perhaps use a button inputs?
‎2022-10-10 12:22 AM
Hi @Community member​ and @Community member​
I am not interested in using the NRST pin as GPIO but only the PA13 and PA14 as GPIO
So your opinions are that I should simply code them as GPIO without any other cautions? Neither on the debug side?
What I found in the manual does not help me a lot. Can you take a look at this?
‎2022-10-10 2:32 AM
I don't have first-hand experience with 'G0 in particular, but this is what I did/do in other small-pin-count models, .eg. 'F0 and 'L0.
