How to use JSON library in st micontrollers
Ss.61
  • I want to use JSON library to send customized data to server
  • Where i can get the library?
  • Micro controller connected with modem (sim900a)
  • Motive is to how to send Json formatted data from st controller to server.
*My controller is :STM32F042G6
5 REPLIES 5
Sebastiaan
Senior
JSON is more complex to parse than to construct. For constructing a fixed json string (which is what you need), snprintf() should work fine IMO.
If you need parsing, it's probably best to copy implementations like cJSON https://github.com/DaveGamble/cJSON.
Sebastiaan
Ss.61
Than you for your quick reply once i will check & update it.
Ss.61
*My requirement is not parsing (incoming data) ,
*I want to use Json On Outgoing Data (From Controller)
Sebastiaan
Senior
int main()
 char json[20] = {0};
 char temp[] = "world";
 snprintf(json, sizeof(json), "{\"hello\": \"%s\"}", temp);
 printf("%s", json);
=> result is {"hello": "world"}
Understood thank you for your quick reply.
