How to test GPIO interrupt handlers
‎2024-12-24 2:29 AM - last edited on ‎2024-12-24 3:22 AM by mƎALLEm
We are developing software that uses GPIO interrupts.
We would like to test if the GPIO interrupt handler is working properly, but is it possible to set the pin assigned to the GPIO interrupt High/Low in software?
Is this only possible by inputting a signal to the target GPIO from outside?
- Labels:
GPIO-EXTI
STM32H7 Series
‎2024-12-24 3:21 AM - edited ‎2024-12-24 3:24 AM
Hello @pass3master ,
In next time please provide the MCU part number.
Yes it's possible to set the rising and falling edges.
Not clear what do you mean by this. As you will use GPIO it's for sure from outside.
Also you refer to one of the examples provided in CubeHAL: https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Projects/NUCLEO-H743ZI/Examples/GPIO/GPIO_EXTI
‎2024-12-24 5:45 AM
On most STM32s you can trigger any NVIC interrupt by software. But you likely want to test the whole path from the pin -> EXTI -> NVIC -> handler. As @mÆŽALLEm said. How to do this? The simplest way: connect the EXTI pin to some other pin configured as push/pull.
‎2024-12-24 6:07 AM
Probably the easiest way is to configure the pin as an output and toggle it. That will trigger the interrupt.
