How to save CNT values from multiple timers via DMA trigger with STM32G473?
KHarb.1
Senior II
I’m using an STM32G473 and I have TIM20 CHANNEL1 configured in output compare mode. When the compare value is reached, I want to move CNT values from TIM1, TIM5, TIM6, TIM7 and TIM15 to 5 static locations in memory.
I’m not sure if I can use DMA to streamline this. I’m using CubeMX and HAL and I’m looking for examples of something like this, but so far I only see DMA examples for transferring to and from the triggering peripheral. Can DMA do this?
You'd need multiple DMA triggered by a common source, say TIMx_UP or TIMx_CCx at zero phase
The transactions wouldn't occur at the same instant.
You might be able to create an Input Capture case where TIMx->CNT moves to TIMx->CCx and then recover the latched value at your leisure.
3 REPLIES 3
... based on master-slave connection between TIM20 and the "target" TIMx...
... or you use the target TIM's CCx signal to trigger DMA of that TIM's CCRx into memory buffer.
That may make your task harder.
I changed the design a bit to allow it to do basically what you're proposing.
