2023-07-09 6:42 AM - edited 2023-07-09 9:22 AM
I am using STM32L4R7VIT which is having OSPI interface and I have connected M9501 Memory which is the single SPI mode memory. I found no example in cube repository or in any post in community which interacted with this issue.
VK Verma
2023-07-10 1:28 AM
Hello @VK Verma,
To configure the OCTOSPI interface for Single SPI mode, I suggest you check AN5050 section 5.2 for OCTOSPI/HSPI configuration for Regular-command protocol.
Also, the AN5050 section 6 OCTOSPI application examples can help you to configure the OCTOSPI interface with different modes such as HyperBus, Octo-SPI and Quad-SPI.
I hope this help you!
When your question is answered, please close this topic by choosing "Accept as Solution". This will help other users find that answer faster.
Kaouthar
2023-07-10 1:28 AM
Hello @VK Verma,
Kaouthar
