STM32H735 problem
kuxiang
The two buttons next to the STM32H735 I bought fell off during the shipping process. Will this have a great impact on the use?
Peter BENSCH
Welcome @kuxiang, to the community!
you are probably talking about the STM32H735G-DK, right?
If only the plastic caps (blue and black) have fallen off, the buttons are still operable and probably functional (reset and user button).
If, on the other hand, the entire buttons have been torn off, you would no longer have any of the above-mentioned functions, but you would not significantly disturb the other functions of the board. Nevertheless, in this case you should consider the possibility of repairing or re-soldering the buttons, depending of course on the extent of the damage.
Alternatively, you should inform your delivery service of the damage and request compensation.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Thank you for your response. I have tested it, and the buttons are functioning correctly, so there should be no problem. Thank you.
Sincerely,
kuxiang
Great!
If the problem is solved, please mark this thread as answered by selecting Accept as Solution, as also explained here. This will help other users find that answer faster.
/Peter
