How to get started with FATFS, USB and HDMI
DJ1
Hi everyone i am new to using peripherals like HDMI and USB with my applications and i wanted to get started with it but i didnt simply want to go with HAL libraries instead i want to understand the basics of them and how to start from scratch. Also for SD cards and USB file storing system i think FATFS file system is also essential so please throw some light on that too if possible. Also please share your suggestions if any.
As of now i am using STM32F401RE Nucleo board which support OTG-FS and in CubeMQ shows FATFS in Middleware but i have no idea on how to start.
3 REPLIES 3
Pavel A.
Evangelist III
If you have a project on your mind and not sure how to start, how the hardware works and which libraries to use - you can find a helper here: https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot  Good luck!
Okay but is there any references so that i can start by myself.
here see examples etc...
https://github.com/STMicroelectronics/STM32CubeF4/tree/master/Projects/STM32F411RE-Nucleo
