How to enable the ART accelerator on STM32F76x processors?
‎2021-09-23 11:03 AM
I'm wondering if the following is correct for using the ART flash accelerator on the STM32F7 line:
- Change linker script to use the ITCM instead of the AXIM bus for FLASH memory.
- In the startup code, enable the ART accelerator by setting the ARTEN bit of the FLASH_CR register.
- Do I need to do anything to the Flash Latency Registers or should I keep it at the recommended level for my processor clock/voltage (6ws for 200mhz @ 3.3v)
We don't program the flash from application, so is it best to use ITCM with ART or AXIM and enable caching?
- Labels:
STM32F7 Series
‎2021-09-23 11:09 AM
@Sylvie Boube-Politano​
‎2021-09-23 1:16 PM
I think I've got it now:
- Change the linker script as above to use the ITCM.
- Enable the ART (ARTEN) in the FLASH_ACR Register
- Enable the ART Prefetch Enable flag (PRFTEN) in the FLASH_ACR Register
For future people: you leave the Flash Latency set as described in the reference manual.
The second half of the dm above helped a lot, plus finding and studying the matching code at:
‎2021-09-23 1:51 PM
Yes, because the flash array has a fixed (slow, say 35ns) speed which needs to be accommodated in CPU clock cycles, that the synchronous design also uses for the ART and FLASH interfacing logic.
