How to burn (download) a program into a Micro if I am not using a Experimental board as Discovery board....
2022-07-05 5:58 PM
Hi ST_community.
"Programing STM32F429ZIT6 micro"
I have a question: what are the options to burn/download a program into a STM32F429?
At this moment, I am working on STM32F429ZIT6-DISC1 board, now, everything is ok, everything is done it throughout ST_Link (I was checking the board and it has an STM32F103 to support the USB ST LINK).
So, at this moment, I don`t have an idea how to program the STM32F419 if the MCU is not on STM Discovery board.
After some test, I will need to design a board (with all electronic components that my project is using), and I will need to transfer the program/debug it....
Can you tell what is the best way to do it, please?
Any comment/advice is welcome.
br
Alfredo
DEBUG
STM32F4 Series
2022-07-05 6:16 PM
Add a JTAG/SWD header on the board so you can connect an external pod, like an ST-LINK/V2, Segger J-LINK, etc
General programming could be done via a serial port, or USB. See App Note AN2606
2022-07-06 3:28 AM
You can use the connector CN2 and CN4 of the DISC1. This allows to use the STLINK of the DISC1 to flash/debug another MCU.
Have a look to the DISC1 schematics: https://www.st.com/en/evaluation-tools/32f429idiscovery.html#cad-resources
This is a wonderful feature of older development boards. News with STLINK-V3 lost this possibility. Sigh...
2022-07-06 5:58 PM
Hi Tesla DeLorean.
Thanks a lot for your quickly answer.
I was checking the APP Note AN2606, so using USART1 (for example) we can flash/debug the MCU, boot0 (PIN 138) must be connected to GND, so, Main Flash memory is selected as boot space.
So, the ST-LINK V2 (wired as TX-RX(MCU), RX-TX(MCU), GND-GND(MCU) and VDD-VDD(MCU)) using pins: PA10 and PA9, it should work
I hope I understood correctly, if not please, let me know it...
again, thanks a lot for your comment/advice.
Br
Alfredo
2022-07-09 9:12 AM
The Nucleo boards with STLINK-V3 still have MIPI10 debug connector.
2022-07-09 2:26 PM
The MIPI10 connector allows to configure the NUCLEO local MCU with an external tool, while STLINK-V3 is disabled by JP1 (UM2505 Page 12).
AFAIK the STLINK can't be disconnected from the local MCU, therefore impossible to drive an external MCU.
I wonder what kind of tools this connector is intended for, because I don't see the point of using a tool other than the local STLINK-V3 on a NUCLEO board.
I think that since ST now has tools like the STLINK-V3MINIE, they don't want users to be able to do the same thing with a NUCLEO board!
2022-07-11 1:34 AM
"....boot0 (PIN 138) must be connected to GND..." ? I may not be understanding what you are trying to do, but if you connect BOOT0 pin directly to ground you will be limiting your programming options. I connect the Boot0 pin to a pull-down resistor (10k?) and a test pad/hole. That way I can pull the pin high using a spring loaded probe in a programming/test jig when I need to re-program/test. My jig connects to GND, VCC, TX, RX, BOOT0 via spring loaded test probes (my boards tend to be smallish, so I don't have much room for connectors)
2022-07-11 5:25 PM
Hi gregstm.
When I said PIN 138 connected to GND, I was thinking in a final project board, no in an experimental board, but I was thinking to use a header to be used when I needed to burn the program or change it any time I need if it necessary..... but always thinking to use Flash area..... is it wrong? Maybe I am trying to do something that is not correct.....
As I told you, my idea is to make a final board...but having the option to burn/replace the MCU program.....
any comment/advice is wellcome...
br
Alfredo
