How do I identify Brown out reset (BOR) condition from embedded software?
2021-02-15 11:59 PM
I would like to distinguish POR/PDR and BOR condition. Let me know if there is a way to identify this from embedded software for stm32l072cz.
Power
STM32L0 Series
2021-02-23 5:41 AM
Hi @CDesh & @KnarfB ,
Comparing both reference manuals of both STM32L4 and STM32L0 and precisely RCC_CSR register, I noted that bit 27 is described as following:
- STM32L4
- Bit 27 BORRSTF: BOR flag. Set by hardware when a BOR occurs. Cleared by writing to the RMVF bit.
- 0: No BOR occurred
- 1: BOR occurred
- STM32L0
- Bit 27 PORRSTF: POR/PDR reset flag. This bit is set by hardware when a POR/PDR reset occurs. It is cleared by writing to the RMVF bit.
- 0: No POR/PDR reset occurred
- 1: POR/PDR reset occurred
So either for L4 or L0, the flag is the same and it is set when a power reset occurs.
In STM32L0, BOR is not available on all devices.
So for both STM32L0 & STM32L4, we can identify POR/PDR/BOR condition based on the bit 27 of RCC_CSR register.
Hope my answer helped you, when your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
-Amel
2021-02-16 12:12 AM
Evaluate the __HAL_RCC_GET_FLAG(RCC_FLAG_BORRST) flag and related reset causes at the very beginning of main. Use __HAL_RCC_CLEAR_RESET_FLAGS() to clear the flags after evaluation.
hth
KnarfB
2021-02-16 12:19 AM
Thanks for your quick response.
I do not see RCC_FLAG_BORRST flag availability in stm32l0cz MCU. Is there a way to include this flag to my MCU which is available in stm32l4xx.
2021-02-16 12:50 AM
Ooh, you're right. That's different from other families. No idea, sorry. Maybe it cannot be distinguished from a POR?
2021-02-23 5:41 AM
- STM32L4
- 1: BOR occurred
- STM32L0
-Amel
2021-02-23 6:29 AM
@Amel NASRI Thanks for your response.
Is it by part number of STM32L0, where I can identify if BOR is available or not?
If BOR is available, once again how do identify it be different from POR/PDR?
is BOR enabled by default on STM32L0 (where BOR is available)?
2021-02-24 5:59 AM
Hi @CDesh ,
BOR is not available for devices operating from 1.65 to 3.6 V and the power supply is monitored by the POR/PDR in this case.
For devices operating from 1.8 to 3.6 V, the BOR is always active and unless disabled by option byte it will mask the POR/PDR threshold.
This means that the POR and PDR are used only when the BOR is disabled.
All these details are available in the reference manual RM0367. Have a look to the section 6.2 Power supply supervisor for some more details.
-Amel
