How can represent logical gates in software of STM32F429I?
AAbed.1
Hi All;
I am working on an STM32F429I timer (PWM-mode1) to obtain two signals then I want to use AND gate inside the program (the input is the two signals come from timer Ch1 &Ch2) and designate one pin to be the final output.
16 REPLIES 16
S.Ma
Principal
If you use the same timer for the compare toggles, you will be guaranteed synchronized generation.
is that ok
HAL_GPIO_WritePin(GPIOG,GPIO_PIN_9, ( HAL_GPIO_ReadPin(GPIOD, GPIO_PIN_5) && HAL_GPIO_ReadPin(GPIOC, GPIO_PIN_8))? GPIO_PIN_SET : GPIO_PIN_RESET);
I want to design the following signal ---->>>>
Assuming your waveform is periodic, it's equivalent to starting the first pulse at t=0 and the second pulse at T=T/2. I'm sure you could manage that with two synchronized timers. Not sure about two channel within the same timer.
You could even keep the centers at 0.25T and 0.75T using center-aligned mode.
yes.
Do you have example about that
