Hello, I'd like to make a data acquisition system for 2 vibrations sensors with a sample rate of at least 10kHz and a 16 bits ADC resolution. I was looking at the SMT32H743ZI2 but it's not available, do you know any other boards/systems that could work?
NicoBeru
NicoBeru
Yeah, I'm a newbie with STM32 boards, it's just because I found a similar project as the one I intend to do with a H743... Thanks to your answer, I just ordered a STM32H7B3I-DK which was available and will probably fit better my needs with the micro-SD slot :-)
4 REPLIES 4
MM..1
Chief II
for what 16bit resolution?
NicoBeru
For the analog to digital converter, to measure vibrations signals from piezoelectric sensors (VS-BV203-B from Kemet) and I'd like this conversion to be with a 16 bits resolution.
The NUCLEO-H743ZI2 is a BOARD
It doesn't have any storage on it, but might be easier to interface circuits too. There are a whole range of NUCLEO-144 boards, what particular about the one with the STM32H743 was important with respect to your selection of it?
10 KHz is not a high rate for ADC, the H7 perhaps has the resolution you seek.
Perhaps look at the DISCO boards, they frequently have MicroSD card slots
NicoBeru
