FDCAN2 doesn't seem to work with STM32G474e-EVAL board
‎2023-05-19 7:26 AM
I'm having problems getting my software to work with FDCAN2 on the STM32G474e-EVAL board. It works with FDCAN1, but w/ FDCAN2, messages accumulate in the Tx buffer until I get buffer fill errors.
I built the FDCAN_Com_IT example from the latest STM32GCube firmware bundle and it fails in the exact same manner. Board is terminated correctly and I believe the CAN pins are wired to each other correctly. What could be going wrong here? Thanks.
-es
FDCAN
STM32G4 Series
‎2023-07-03 9:03 AM
Ok, finally tracked this problem down. It would appear that some revisions of the STM32G474E-EVAL board default to having the FDCAN2 TX pin disconnected. If you solder the SB5 location on the board closed, the pin will be connected and FDCAN2 will work.
‎2023-07-04 1:56 AM
Hello @ESchn.1 ,
Glad to know that the issue is already fixed.
Thank you for your sharing the solution :).
Yes, you are right the FDCAN2 TX is initially disconnected in G474EMC-B04 Board revision, SB5 is open by default, contrary to G474E-B04 Board revision
Thank you for your contribution in STCommunity.
Kaouthar
- « Previous
- 1
- 2
- Next »
