F767 TIM12 PWM HAL not working
PKlar.1
I tried really hard to get the TIM12 working, but I had absolutely no success... I already do PWM on TIM1 and TIM4. So I tried with same settings to setup TIM12, but it does not work. The question now is: Why?
What do I use?
STM32CubeIDE 1.3.0
I set up everything in the CubeIDE environment inside of stm32cubeIDE.
So here is my main.c, where I just want to turn TIM12 on. Nothing else is configured except one GPIO to hold the power supply active:
I did read about some difficulties with TIM12/TIM8, but I did not found any solution.
I would be really happy, if someone has has a hint, what extra thing is necessary to get TIM12 working.
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
#include "main.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
TIM_HandleTypeDef htim12;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_TIM12_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_TIM12_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @retval None
void SystemClock_Config(void)
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    Error_Handler();
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  * @brief TIM12 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN TIM12_Init 0 */
  /* USER CODE END TIM12_Init 0 */
  TIM_OC_InitTypeDef sConfigOC = {0};
  /* USER CODE BEGIN TIM12_Init 1 */
  /* USER CODE END TIM12_Init 1 */
  htim12.Instance = TIM12;
  htim12.Init.Prescaler = 36000;
  htim12.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim12.Init.Period = 18000;
  htim12.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim12.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_PWM_Init(&htim12) != HAL_OK)
    Error_Handler();
  sConfigOC.OCMode = TIM_OCMODE_PWM1;
  sConfigOC.Pulse = 0;
  sConfigOC.OCPolarity = TIM_OCPOLARITY_HIGH;
  sConfigOC.OCFastMode = TIM_OCFAST_DISABLE;
  if (HAL_TIM_PWM_ConfigChannel(&htim12, &sConfigOC, TIM_CHANNEL_1) != HAL_OK)
    Error_Handler();
  sConfigOC.OCPolarity = TIM_OCPOLARITY_LOW;
  if (HAL_TIM_PWM_ConfigChannel(&htim12, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM12_Init 2 */
  HAL_TIM_PWM_Start(&htim12, 1);    //starts PWM
  HAL_TIM_PWM_Start(&htim12, 2);    //starts PWM
  /* USER CODE END TIM12_Init 2 */
  HAL_TIM_MspPostInit(&htim12);
  * @param None
  * @retval None
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOB_CLK_ENABLE();
  __HAL_RCC_GPIOG_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOG, GPIO_PIN_8, GPIO_PIN_SET);
  /*Configure GPIO pin : PG8 */
  GPIO_InitStruct.Pin = GPIO_PIN_8;
  HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
11 REPLIES 11
PKlar.1
I also tried it with TIM8, but does not work either on the same pins.
I tried also to enable the TIM Interrupts, but they do not get fired.
  * @file           : main.c
  * @attention
#include "main.h"
TIM_HandleTypeDef htim8;
static void MX_TIM8_Init(void);
  * @retval int
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_TIM8_Init();
  /* Infinite loop */
  while (1)
  * @retval None
    Error_Handler();
    Error_Handler();
  * @brief TIM8 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN TIM8_Init 0 */
  /* USER CODE END TIM8_Init 0 */
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  TIM_BreakDeadTimeConfigTypeDef sBreakDeadTimeConfig = {0};
  /* USER CODE BEGIN TIM8_Init 1 */
  /* USER CODE END TIM8_Init 1 */
  htim8.Instance = TIM8;
  htim8.Init.Prescaler = 62000;
  htim8.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim8.Init.Period = 31000;
  htim8.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
  htim8.Init.RepetitionCounter = 0;
  htim8.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE;
  if (HAL_TIM_PWM_Init(&htim8) != HAL_OK)
    Error_Handler();
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterOutputTrigger2 = TIM_TRGO2_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  if (HAL_TIMEx_MasterConfigSynchronization(&htim8, &sMasterConfig) != HAL_OK)
    Error_Handler();
  sConfigOC.Pulse = 20000;
  sConfigOC.OCNPolarity = TIM_OCNPOLARITY_HIGH;
  sConfigOC.OCIdleState = TIM_OCIDLESTATE_RESET;
  sConfigOC.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  if (HAL_TIM_PWM_ConfigChannel(&htim8, &sConfigOC, TIM_CHANNEL_2) != HAL_OK)
    Error_Handler();
  sConfigOC.OCNPolarity = TIM_OCNPOLARITY_LOW;
  if (HAL_TIM_PWM_ConfigChannel(&htim8, &sConfigOC, TIM_CHANNEL_3) != HAL_OK)
    Error_Handler();
  sBreakDeadTimeConfig.OffStateRunMode = TIM_OSSR_DISABLE;
  sBreakDeadTimeConfig.OffStateIDLEMode = TIM_OSSI_DISABLE;
  sBreakDeadTimeConfig.LockLevel = TIM_LOCKLEVEL_OFF;
  sBreakDeadTimeConfig.DeadTime = 0;
  sBreakDeadTimeConfig.BreakState = TIM_BREAK_DISABLE;
  sBreakDeadTimeConfig.BreakPolarity = TIM_BREAKPOLARITY_HIGH;
  sBreakDeadTimeConfig.BreakFilter = 0;
  sBreakDeadTimeConfig.Break2State = TIM_BREAK2_DISABLE;
  sBreakDeadTimeConfig.Break2Polarity = TIM_BREAK2POLARITY_HIGH;
  sBreakDeadTimeConfig.Break2Filter = 0;
  sBreakDeadTimeConfig.AutomaticOutput = TIM_AUTOMATICOUTPUT_DISABLE;
  if (HAL_TIMEx_ConfigBreakDeadTime(&htim8, &sBreakDeadTimeConfig) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN TIM8_Init 2 */
  /* USER CODE END TIM8_Init 2 */
  HAL_TIM_MspPostInit(&htim8);
	HAL_TIM_PWM_Start(&htim8, 1);    //starts PWM
	HAL_TIM_PWM_Start(&htim8, 2);    //starts PWM
  * @param None
  * @retval None
  * @retval None
  * @retval None
Read out and check/post content of TIM12 and relevant GPIO registers.
PS Is this intended?
PKlar.1
thanks for your quick answer. I just was back at the office today.
According to your question about the Pulse: As you can see in my second post I did enter there a different value as 0, but it does not make any difference. Like I said, TIM8 and TIM12 are on the same pin (the one I would like to use), and both are not working.
So I guess, if we work TIM8 out, TIM12 will work accordingly.
So, I made three screenshots for you with TIM8.
First one before initializing timer, one after initializing but before HAL_TIM_PWM_Start, and one after HAL_TIM_PWM_Start.
Before TIM_Init:
After TIM_Init, but not started:
After TIM_init and after Start:
Thanks in advance.
You have CH2 and CH3 set up for PWM, in CCMRx and in CCER you have enabled CH1N (with polarity changed for CH1) and changed polarity for CH3N - neither of CH2/CH2N/CH3/CH3N are enabled.
So this can't work.
Besides, you did not say which pins, and did not show the relevant GPIO registers content.
PKlar.1
Ok, thanks for figuring that out. Do you know what I need to change in CubeMX or in the config using the HAL Library?
It should go to PB14 and PB15.
The GPIO Init is done in the PostInit function:
void HAL_TIM_MspPostInit(TIM_HandleTypeDef* htim)
  if(htim->Instance==TIM8)
  /* USER CODE BEGIN TIM8_MspPostInit 0 */
  /* USER CODE END TIM8_MspPostInit 0 */
    /**TIM8 GPIO Configuration
    PB14     ------> TIM8_CH2N
    PB15     ------> TIM8_CH3N
    GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_15;
    GPIO_InitStruct.Alternate = GPIO_AF3_TIM8;
  /* USER CODE BEGIN TIM8_MspPostInit 1 */
  /* USER CODE END TIM8_MspPostInit 1 */
I don't use CubeMX/Cube/HAL, sorry.
Try to review the available examples in Cube, if you want to stick to Cube.
Or read the reference manual and go for register-level programming. It's really not that complicated, I have some examples - even if not for 'F767 - on my website efton.sk/STM32, or you can find examples here if you look for berendi's posts.
PKlar.1
I started to look into the register thing, it is really a bit confusing to me. Can I kindly ask you: What exactly should be different in the timer register setting from the screenshot above provided?
The goal is to have on PB14 (TIM8 CH2N) and on PB15 (TIM8 CH3N) a complimentary PWM, that's why I changed polarity for one channel.
Basically, in the above example, you only need to set in CCER bits CC2NE and CC3NE, to enable CH2N and CH3N.
The rest appears to be OK: ARR is nonzero; timer is running as it's enabled by CR1.CEN - this is witnessed by changing CNT when observed in debugger; PWM for both CH2 and CH3 is set by setting CCMRx.OCxM to 0b110; CCR2/CCR3 are set to values below ARR; and as it's an Advanced timer, BDTR.MOE has to be and is indeed set, too.
Read the TIM registers' description in RM.
In GPIO, you will need to set the respective pins' MODER to AF and in the respective AFR register, set the required AF for them, according to the pinout table in Datasheet. This all only after you've enabled the given GPIO's clock in RCC.
You don't need to program to try this - simply change the registers directly in the debugger.
PKlar.1
Ok, found out what my error was. Channel 1 and 2 are not 1 and 2 in decimal. Its' 0 and 4.
It is defined in stm32 HAL correctly:
#define TIM_CHANNEL_1           0x00000000U             /*!< Capture/compare channel 1 identifier   */
#define TIM_CHANNEL_2           0x00000004U             /*!< Capture/compare channel 2 identifier   */
So, when we write:
HAL_TIM_PWM_Start(&htim12, TIM_CHANNEL_1); //starts PWM
HAL_TIM_PWM_Start(&htim12, TIM_CHANNEL_2); //starts PWM
then it is correct.
It was my mistake. I wrote;
Thats why CCER register was not set correctly.
