Error localhost:61234: Connection timed out.
ADębs.1
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
Why?
18 REPLIES 18
CAN YOU PLEASE GIVE THE SOLUTION FOR THIS.
I try everything for this but not solved this issue.
Did u get the solution
RomainFR
Hello, I have the same probleme and I don't find how to solve it on the web :frowning_face:
SGasp.1
Hi @ADębs.1  any news?
S3b
same problem :(
S3b
But, i have resolve my problem (bad config) :
"Debug configuration..." > "Debugger"
 - Change :  "[X] Connect to remote GDB server" to "[X] Autostart local GDB serveur".
 - Chek if "Debug probe" is "ST-LINK (ST-LINK GDB serveur).
 - And :  "[X] ST-LINK S/N" and press "[Scan]".
SGasp.1
@S3b   i have tried but nothing. my st link is hot when i touch it
lironavrhmov
Make sure both of the st-link jumpers on your board are exist.
xp-dv
What fixed the issue for me was removing a misplaced jumper that was causing the board to be stuck in the reset state. Check the user manual of your board for what jumpers are needed for what function, then remove the jumpers that are out of place. You can search "jump" or "JP" to make searching the manual faster.
