2024-08-19 4:36 AM - last edited on 2024-08-19 4:43 AM by Peter BENSCH
I'm using stm32H750B-DK and i'm trying to send a frame via LIN protocole every one second .
but when i run the code nothing happen .
when debugging i found that the code blocked in an endless loop in SCB_EnableDCache() function
2024-08-21 6:40 AM
I didn't reproduce your behavior from my side by stepping over SCB_EnableDCache(). Do you have another board to do the same test?
2024-08-21 6:44 AM
No i don't But like i said toggling the led and TouchGFX are working fine .
But toggling the led didn't work unless i created a task and not in the while loop
2024-08-22 5:16 AM
There is no data sent from the touchGFX .But when i used the stlink port to send it worked but when i use the Arduino connectors TX/RX it didn't work
2024-08-22 6:25 AM
This is a TouchGFX issue not related to the original question "endless loop in SCB_EnableDCache()".
You already created this new thread regarding this question: https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/problem-while-sending-a-lin-frame-from-touchgfx/td-p/711283
