diffrence between stm32f29i-disc1 and stm32f429zi
‎2024-11-19 10:34 PM - last edited on ‎2024-11-20 12:45 AM by Andrew Neil
hello what is the diffrence between stm32f29i-disc1 and stm32f429zi
STM32F4 Series
‎2024-11-20 1:40 AM - edited ‎2024-11-20 1:46 AM
@mÆŽALLEm wrote:Need to explain to us what do you need behind your original question: "diffrence between stm32f29i-disc1 and stm32f429zi"
@syedhashmiraza is misunderstanding / misusing the term, "microcontroller"; eg,
@syedhashmiraza wrote:hello i am using stm32f429i-disc1 microcontroller (sic)
See: https://community.st.com/t5/stm32-mcus-products/use-stm32f4-flash-for-non-volatile-data-storage-eeprom/m-p/743291/highlight/true#M266284 - and several other places in that thread.
@syedhashmiraza The stm32f429i-disc1 is not a microcontroller - it is a board which contains, among other things, a microcontroller.
The microcontroller is the stm32f429zi
‎2024-11-19 10:38 PM - edited ‎2024-11-19 10:43 PM
stm32f429i-disc1 is a board containing stm32f429zi microcontroller
‎2024-11-19 10:46 PM
i did not understanding what are you telling can you tell some points off thesee two boards and what are those diffrence
‎2024-11-19 11:05 PM
first, there is no board called stm32f29i-disc1 I supposed you are talking about stm32f429i-disc1. So please provide the correct board name.
second, as I said they are different disc1 termination means it’s a board : https://www.st.com/en/evaluation-tools/32f429idiscovery.html
while stm32f429zi is a microcontroller:
https://www.st.com/resource/en/datasheet/stm32f427vg.pdf
Hope that answers your question
‎2024-11-20 12:47 AM - edited ‎2024-11-20 12:57 AM
@syedhashmiraza wrote:i did not understanding what are you telling c
The difference between a chip and a board:
In this case, this is the STM32F429I-DISC1 board:
And this is the stm32f429zi chip (a microcontroller) - mounted on the rear of the board:
‎2024-11-20 1:03 AM
you mean these two boards are same
‎2024-11-20 1:04 AM
What words you are talking about?
‎2024-11-20 1:10 AM - edited ‎2024-11-20 1:29 AM
@syedhashmiraza wrote:you mean these two boards are same
No - see my earlier reply.
There is only one board.
Only the stm32f429i-disc1 is a board.
stm32f429zi is not a board; it is just a chip - a microcontroller.
PS:
The board includes all these things:
As you can see, the chip (the microcontroller) is just one thing (among many other things) on that board.
‎2024-11-20 1:19 AM - edited ‎2024-11-20 1:54 AM
This is what I meant in my first comment:
stm32f429zi is the microcontroller (a chip or integrated circuit) which is the main component of the board stm32f29i-disc1.
