Differences between the Nucleo-144 STM32H743ZI2 and STM32H743ZI
J.Bepler
I'm stuck trying to understand the differences between the two Nucleo-144 boards
STM32H743ZI (seems to be the older version but with lots of resources but outdated)
and
STM32H743ZI2 (current version but i can hardly find working examples and resources)
can someone point me in the right direction?
why do some examples designed for the ZI not work on the ZI2 ?
where exactly are the diferences, at first glance they seem identical.
Related defines, check stm32h7xx_nucleo_conf.h
USE_HAL_DRIVER, STM32H743xx, USE_NUCLEO_144
USE_NUCLEO_H743ZI
USE_NUCLEO_H743ZI2
LED2
PB7 BLUE (ZI)
PE1 YELLOW (ZI2)
ARDUINO D4
PF14 (ZI)
PE14 (ZI2)
ARDUINO D8
PG9 (ZI)
PF3 (ZI2)
PE2 QSPI/SAI CONFLICTED
PB13 SAI/ETHERNET CONFLICTED
PA7 D11/ETHERNET CONFLICTED
QSPI CS
PB6 (ZI)
PG6 (ZI2) or PB6 will SB made
Read the notes and solder-bridge options/defaults
MB1137 UM1974 (ZI)
https://www.st.com/resource/en/user_manual/um1974-stm32-nucleo144-boards-mb1137-stmicroelectronics.pdf
https://www.st.com/resource/en/schematic_pack/nucleo_144pins_sch.zip
MB1364 UM2407 (ZI2)
https://www.st.com/resource/en/user_manual/dm00499160-stm32h7-nucleo144-boards-mb1364-stmicroelectronics.pdf
https://www.st.com/content/ccc/resource/technical/layouts_and_diagrams/schematic_pack/group1/79/99/be/65/3c/76/40/d6/MB1364-H743ZI-C01_Schematic/files/MB1364-H743ZI-C01_Schematic.pdf/jcr:content/translations/en.MB1364-H743ZI-C01_Schematic.pdf
https://paypal.me/cliveone
5 REPLIES 5
Handful of pins related to LEDs, QSPI and ETHERNET, as I recall, reducing/removing some potential stubs. Solder Bridges and default usage expectations.
Different HSE clock furnished by ST-LINK/V3​
J.Bepler
could you go ito detail about the ethernet pins particularly? where did you find documentation that explains that?
FBL
Please check DB3171 for more details.
You can also check the user manual UM2407 and board reference MB1364
I'm out of offce with limited access to my emails.
Happy New Year!
I went through the manual and schematic whilst porting some QSPI support.
Perhaps start by looking at the MORPHO​ connector.
USE_NUCLEO_H743ZI
USE_NUCLEO_H743ZI2
LED2
PB7 BLUE (ZI)
PE1 YELLOW (ZI2)
ARDUINO D4
PF14 (ZI)
PE14 (ZI2)
ARDUINO D8
PG9 (ZI)
PF3 (ZI2)
QSPI CS
PB6 (ZI)
MB1137 UM1974 (ZI)
MB1364 UM2407 (ZI2)
