Could not set IWDG timeout to max (~32s) for STM32G031?
Ccui.1
I am using Nucleo-G031K board and attempt to set IWDG timeout to max value of ~32s. Got hard fault. Here is the code. Any idea?
 iwdg_hIwdg.Instance = IWDG;
 iwdg_hIwdg.Init.Prescaler = IWDG_PRESCALER_256;
 iwdg_hIwdg.Init.Window = IWDG_WINDOW_DISABLE;
 iwdg_hIwdg.Init.Reload = 4095;
 if (HAL_IWDG_Init(&iwdg_hIwdg) != HAL_OK)
  iwdg_ErrorHandler();
7 REPLIES 7
Other values work?
Did you try with a simple "blinky" program?
> Got hard fault.
Then debug it as usually with hardfaults.
Ccui.1
Other values work. For example, the following code works as expected.
 iwdg_hIwdg.Init.Prescaler = IWDG_PRESCALER_128;
I will checkout sample application.
And using the same prescaler but different reload value?
PDAMN.1
Hello
I have the same problem as you. Did you find the solution?
Can you help me ?
Thank you
Ccui.1
HAL_IWDG_DEFAULT_TIMEOUT could be as high as 48ms. I configured system tick for 0.5ms. After I more than doubled the value as shown below
/* Status register need 5 RC LSI divided by prescaler clock to be updated. With
  higher prescaler (256), and according to LSI variation, we need to wait at
  least 6 cycles so 48 ms. */
#define HAL_IWDG_DEFAULT_TIMEOUT      110 // 48u
it works.
pierre-yves
Hello
To test, I modified the define:
#define HAL_IWDG_DEFAULT_TIMEOUT 2000
it is indeed the macro IWDG_ENABLE_WRITE_ACCESS (hiwdg) which generates an error (HardFault_Handler).
I also changed the values
hiwdg.Instance = IWDG;
hiwdg.Init.Prescaler = IWDG_PRESCALER_128;
hiwdg.Init.Window = IWDG_WINDOW;
hiwdg.Init.Reload = 4095;
Not easy .... any ideas? .. I block
Thnak you
pierre-yves
In fact it is indeed a timeout error made by the HAL_IWDG_Init function. But I don't know what to do.
I am in version 1.3.0 at the HAL software
