2023-08-13 6:20 AM
Hello , is there a way I can convert an stlink to jlink in linux (ubuntu 22.04). STSW-LINK009 is only available for windows
2023-08-13 7:36 AM
1. Try to run it under Wine. 2. Install Windows in a virtual machine.
2023-08-13 10:05 AM - edited 2023-08-13 10:06 AM
You don't need any driver on Linux... st-link is working always, If working st-link is connected.
No need for j-link.
2023-08-13 11:42 PM
I'm trying to debug zephyr (rtos) code from vs-code and seems stlink ,stutil server executable could not be found I tried to install stlink-tools still didn't work , so I opted for installing jlink which whose executable was found , so I'm trying to convert the stllink to jlink to enable debugging ,
2023-08-14 12:43 AM
on some boards you can convert st-link to j-link, but need windows system to do this (afaik)
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
otherwise you have to buy a j-link.
