2024-03-16 04:08 AM - last edited on 2024-09-24 05:15 AM by Amel NASRI
I want to supply my St Iot discovery kit board with a battery supply, I have changed the header pin to 5V_VBAT. As i am connecting my battery to the Vin and gnd pins the red LED keeps blinking and LD5 is off.
Kindly give some suggestions how should I fix this.
I am using a 5v rechargeable battery for this, can I use a 9v battery for the same or it will damage the board ?
2024-03-16 05:15 AM
Hello @Arhum_29
I suggest you to take a look at the part 7.4 of the UM2153 where you can find more details about how to supplie your board.
Best Regards.
STTwo-32
