Configure Timer Input Capture
Fede Rico
Posted on November 10, 2017 at 08:25
I'm trying to measure the frequency of a PWM signal ( 600 Hz) with the Input Capture functionality with an STM32F103.
I do these steps:
  • Configure the Tim4 as Input Capture.
    • Timer Clock 64 MHz;
    • Prescaler = 0;
    • Period = 65535.
This is the callback invoked when a rising edge is detected:
void HAL_TIM_IC_CaptureCallback( TIM_HandleTypeDef *htim )
uint16_t capturedValue;
uint16_t delta;
if( (htim == htim4) && (htim->Channel == TIM_CHANNEL_4 )
channelId = PWM_IC_CHANNEL_FLOW_METER;
/* Get CCR register for the specific Timer and Channel */
capturedValue = HAL_TIM_ReadCapturedValue( htim4, TIM_CHANNEL_4 );
if( capturedValue > lastCapturedValue )
/* Compute the input signal frequency */
delta = capturedValue - lastCapturedValue;
else /* Timer counter overflow */
delta = ( 0xFFFF - lastCapturedValue ) + capturedValue;
inputFrequencyHz = ( 64000000 / delta );
/* Update the last captured value */
lastCapturedValue = capturedValue;
Unfortunately I cannot detect the input frequency.
Is my configuration correct? My main concern is how to compute the right timer frequency in relation to input signal frequency
Thanks for the help!
#input-capture-mode #timer #pwm
7 REPLIES 7
Posted on November 10, 2017 at 09:51
What does that mean exactly? Is there no interrupt? Have you verified the input signal is present directly on the mcu pin? In the debugger, look at the timer's registers: does CNT change? Does the respective CCR change?
The calculation is better performed as modulo of the period, which in case of 2^N period which is your case reduces to AND.
delta = (capturedValue - lastCapturedValue) & 0xFFFF;
Posted on November 10, 2017 at 10:01
sorry, I did not express my self.
The IC interrupt is raised, but the computed frequency was wrong.
Now I adjusted the Timer clock frequency to 32 Mhz and I can compute exactly the input signal frequency.
Thanks for the formula, I looking for a better performance formula.
With this formula I can compute the delta in both case: Overflow an no overflow. Using your formula, should be delta an int32_t?
To compute the maximum Timer Frequency I used this formula: f_tim_max < f_signal * 0xFFFF. Am I right?
NOTE regarding the bitwise-and instead of mod:
x modulo y = (x & (y − 1)) - https://stackoverflow.com/questions/6670715/mod-of-power-2-on-bitwise-operators
So your formula should be delta = (capturedValue - lastCapturedValue) & (0xFFFF - 1)
Thanks!
Posted on November 10, 2017 at 11:46
No, because the period is ARR+1=0x10000.
Posted on November 10, 2017 at 11:50
Which questions do you means?
I set the ARR as 0xFFFF.
Should I delta variable as int16_t?
Posted on May 13, 2018 at 12:10
Dear Fede
I hope you have solved your problem for a long time.
I produced two tutorials for my students showing how to configure and to use Input Capture technique for measuring signal frequency.
The simplest one is located at
https://community.st.com/0D50X00009bMMADSA4
The second one is more sophisticated and aims at overcoming the limitations of 16 bit timers only available on stm32L0 MCUs :
https://community.st.com/0D50X00009bMMA8SAO
Bye
JC Toussaint
Posted on May 13, 2018 at 13:06
Note that timer can be configured to measure frequency itself without any maths. Search datasheet for section 'PWM input mode'. In short: timer do capture event and reset itselfs. With every new measured period timer starts from zero => you dont need calculate diferences of capture events ...
Posted on May 13, 2018 at 13:41
Not on CH4 - and that's what the original poster wanted to do.
(Note that this is a half-year old thread, just being resurrected by Jean-Christophe - btw. his solution uses the slave-reset too.)
