Configure SPI on stm32f205
Kolab
Hello!
How can I configure only the MISO pin in the mode falling edge triggered interrupt input? It's not possible to do it on CubeMX. I tried to change the spi.c file like follows:
/**SPI3 GPIO Configuration
  PA15   ------> SPI3_NSS
  PC10   ------> SPI3_SCK
  PC11   ------> SPI3_MISO
  PC12   ------> SPI3_MOSI
  GPIO_InitStruct.Pin = GPIO_PIN_15;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = GPIO_AF6_SPI3;
  GPIO_InitStruct.Pin = GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
GPIO_InitStruct.Mode = I replaced GPIO_MODE_AF_PP; by GPIO_MODE_AF_PP|GPIO_MODE_IT_FALLING|GPIO_MODE_AF_PP;
But it doesn't work. Any help, please?
Kolab
thank you all for your help so far. I realized that only setting on Cube a pin as Alternate Function Push Pull is enough to allow you to use this pin as falling edge triggered interrupt input (as this was need for the ADC ads1118). The problem was actually with the spi3 configuration on Cube: I misconfigured the CPAH. This was the key to solve the issue!
10 REPLIES 10
Guru
I don't think it's possible within the HAL framework. But you can do it by editing registers directly.
Kolab
I got your point. And could you give an example for my case, how it should be done?
S.Ma
Principal
I suggest to configure the Exti interrupt for miso and spi without miso in cube mx, then, after mx init, manually reactivate miso as spi alternate signal. Hack will work. EXTI on alternate function pin works fine even if the HAL didn't foresaw users needing this confuguration and CubeMX based apparently on HAL and not the reference manual.
Kolab
Hello @S.Ma​  let me see if I got you point: you mean activate SPI on CubeMX, then change the MISO pin configuration to GPIO_EXTIx, then after MX init change manually back MISO pin configuration to alternate function?
S.Ma
Principal
You got it, CubeMX is a static HW configuration, you can override it manually.
Kolab
@S.Ma​  can I just reconfigure it inside the functions HAL_SPI_MspInit and HAL_SPI_MspDeInit ?
S.Ma
Principal
Well, run your code with debugger and check if your code insertion work by looking at the gpio and exti registere.... not specialist of hal intricacies.
Kolab
0693W00000DmVoeQAF.pngthe program gets stuck here
S.Ma
Principal
Did you create the exti interrupt handler function? If this looks difficult to you, get a files compare text viewer, generate a simple concisr project for spi and exti, look at both anf try to merge. Exti and spi are decorrelated function. You decide when each one has to be enabled
