Can not debug STM32L552 Nucleo-144 board
2021-05-26 6:24 AM
I can not debug STM32L552 Nucleo-144 board with STM32CubeIDE 1.16.1
Here is output message from IDE:
STMicroelectronics ST-LINK GDB server. Version 5.8.0
Copyright (c) 2020, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
InitWhile : Enabled
Waiting for debugger connection...
Debugger connected
STM32CubeProgrammer v2.7.0-RC1
ST-LINK SN : 0669FF505352716587121336
ST-LINK FW : V2J37M27
Board : NUCLEO-L552ZE-Q
Voltage : 3.26V
SWD freq : 4000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x472
Revision ID : Rev B
Device name : STM32L5xx
Flash size : 512 KBytes (default)
Device type : MCU
Device CPU : Cortex-M33
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a08360.srec
File : ST-LINK_GDB_server_a08360.srec
Address : 0x08000000
Erasing internal memory sectors [0 3]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.231
Verifying ...
Error: Data mismatch found at address 0x08000000 (byte = 0xFF instead of 0x00)
Error: Download verification failed
Encountered Error when opening C:\ST\STM32CubeIDE_1.6.1\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_1.6.0.202101291314\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Debugger connection lost.
Shutting down...
DEBUG
STM32L5 Series
2021-05-26 7:52 AM
Hello @tpeng.1 ,
Can you please try to upgrade the STLink Firmware and then tell me if this resolve the issue ?
It may be the cause of this problem is on the configuration. I suggest you to share the option bytes settings?
Please kepp us about your update.
Imen
Imen
2021-05-26 6:25 PM
Thank you!
To upgrade the STLink does not resolve the issue.
The option bytes which read with STM32 CubeProgrammer:
Name Value Addr
RDP AA
BOR_LEV 0
nRST_STOP Checked
nRST_STDBY Checked
nRST_SHDW Checked
IWDG_SW Checked
IWDG_STOP Checked
IWDG_STDBY Checked
WWDG_SW Checked
SWAP_BANK Unchecked
DB256 Checked
DBANK Checked
SRAM2_PE Checked
SRAM2_RST Checked
nSWBOOT0 Checked
nBOOT0 Checked
PA15_PUPEN Checked
TZEN Checked
HDP1EN Checked
HDP1_PEND Value=0, Addr=0x8000000
NSBOOTADD0 Value=0x1000 Addr=0x8000000
NSBOOTADD1 Value=0x17f200 Addr=0xbf90000
SECBOOTADD0 Value=0x1800 Addr=0xc000000
BOOT_LOCK Unchecked
SECWM1_PSTRT Value=0x0 Addr=0x8000000
SECWM1_PEND Value=0x7f Addr=0x803f800
WRP1A_PSTRT Value=0x7f Addr=0x803f800
WRP1A_PEND Value=0x00 Addr=0x8000000
WRP1B_PSTRT Value=0x7f Addr=0x803f800
WPR1B_PEND Value=0x00 Addr=0x8000000
SECWM2_PSTRT Value=0x01 Addr=0x8040800
SECWM2_PEND Value=0x0 Addr=0x8040000
WRP2A_PSTRT Value=0x7f Addr=0x807f800
WRP2A_PEND Value=0x00 Addr=0x8040000
WRP2B_PSTRT Value=0x7f Addr=0x807f800
WRP2B_PEND Value=0x00 Addr=0x8040000
Br,
Tim
2021-05-27 1:03 AM
Hi @tpeng.1 ,
Maybe this post can help you.
Please keep me updated about your progress on this issue.
Imen
Imen
2021-05-27 1:36 AM
I can program elf file to Nucleo-144 board with STM32CubeProgrammer, but I still can not debug it with IDE.
Br,
Tim
2021-05-27 9:53 AM
Hi @tpeng.1 ,
Can you please try with the following option bytes:
- TZEN=1 (TrustZone-enabled device)
- DBANK=1 (Dual bank Flash configuration)
- SECWM1_PSTRT=0x0 SECWM1_PEND=0x7F
- SECWM2_PSTRT=0x1 SECWM2_PEND=0x0
Imen
Imen
2021-05-27 3:56 PM
Hi Imen,
Thank your help.
The option byte values given from you is the same as the my board settings.
I uncheck the “Verify flash down�? in IDE debug tab. File download complete. When viewing disassembly,
fffffffe: Failed to execute MI command:
-data-disassemble -s 4294967294 -e 4294967434 -- 3
Error message from debugger back end:
Cannot access memory at address 0xfffffffe
ffffffff: Failed to execute MI command:
-data-disassemble -s 4294967295 -e 4294967411 -- 3
Br,
Tim
