someone know if it possible to change LPTIM source mux while running? for example to change from LSI to PCLK1? LSI is 37Khz and I want the PWM to run in 1khz so I use count 37, but I want to generate more step then 37 and still remain in 1Khz for PWM
M4D
M4D
more over I am using LPTIM because I want to be able to use stop mode
any suggestions ?
waclawek.jan
Which STM32?
LPTIM's details are generally not very well described, but I believe you can switch the clock source while running. Those sources are not synchronized and LPTIM is asynchronous, so the timing at around the switching may be not precise, but outside the switching is should be OK.
I am not ST, though.
