2017-05-23 02:39 AM
Hi, I'm using the STM32L152C8U6-A MCU. I want to use the high speed external clock signal (HSE). The HSE is specified for frequencies from 1-24 MHz. I have an 26 MHz c
rystal oscillator
. What happen, if I still use the HSE with my 26 MHzc
rystal oscillator
? Can I use the clock anyway? What are the consequences of this fix?Thank you, best regards.
#hse #clock #stm32l152c8u6-a #oscillator2017-05-23 08:22 PM
If you use the HSE out of the specification:
2017-05-24 02:04 AM
Max,
I believe Remo meant an external oscillator, as in HSE bypass.
Remo,
Please have a look at 6.3.6 External clock source characteristics in the datasheet.
