C++ compiler options.
CPetr.1
 Hi.
I thought this question is more suited to education.
I have been working on a STM32F091 C++ project just to get an idea code size, and I noticed that the size of the binary is huge even when optimisation is set to (-Os). I think its because the compiler is bringing in everything, even when certain functions, and section are not being used, but! I’m not sure.
Generally speaking, is there a way if streamlining my project to cut down on code?
cp
5 REPLIES 5
Guru
You can open up the map file and figure out what's taking so much space. Ensure your linker discards unused code (-WL,--gc-sections)
Remove unnecessary code, don't duplicate code.
Use a reduced library such as nano (--specs).
Avoid using dynamic memory allocation (malloc/free).
The -Os optimization flag should be about the best you can do for size from a compiler standpoint. Might get more with link time optimization (-flto).
CPetr.1
Thanks for your answer TDK.
Where do I place (-WL,--gc-sections) and  (--specs) in the cubeIDE settings.
Guru
In project settings.
CPetr.1
ok, I checked my settings, and that's the way they are set up already. This code I'm using compiles for a mega2560 AVR at just under 128K, but as it is, ported to STM32F091, it generates 241k of code. That a big difference.
CPetr.1
Just to complete this thread, one of the files contained an #include <iostream> statement.
When I removed this, the code size came down to 88K, which seems about right for this project size.
cheers
