2022-01-03 3:55 AM
I was using stm32f4 on my project but now I want to use the h7 products. I am reading referance manual and watching some videos about the arm cortex m7, but I didnt understand completely about the CPU things. How can I learn the most basic way to understand its memory organization ?
This is one of the things i don't understand:
I also exemine the example of the stm32Cube with h7, every examples start with CPU_CACHE_Enable(); , Should I use the this line in every project and why I didnt understand this function using although reading referance manual ?
2022-01-06 7:21 AM
Hi Peter,
On https://www.st.com/en/microcontrollers-microprocessors/stm32h743ag.html#documentation I see Application Notes (5 of 52) and under the 5 appnotes I see Load More. When I click on Load More once, I see all 52 appnotes and no Load More. Within those 52 appnotes, there is no AN4891 (below is the list).
Jan
@Peter BENSCH
AN3126 Audio and waveform generation using the DAC in STM32 products
4.0 08 Jul 2020
AN5020 Digital camera interface (DCMI) on STM32 MCUs
1.0 04 Aug 2017
AN1709 EMC design guide for STM8, STM32 and Legacy MCUs
3.1 09 May 2019
AN1181 Electrostatic discharge sensitivity measurement
1.6 11 Jul 2017
AN5543 Enhanced methods to handle SPI communication on STM32 devices
2.0 05 Jul 2021
AN5342 Error correction code (ECC) management for internal memories protection on STM32H7 Series
2.0 09 Jan 2020
AN4566 Extending the DAC performance of STM32 microcontrollers
3.0 19 Sep 2019
AN5348 FDCAN peripheral on STM32 devices
1.0 07 Oct 2019
AN5405 FDCAN protocol used in the STM32 bootloader
2.0 28 Jun 2021
AN4776 General-purpose timer cookbook for STM32 microcontrollers
3.0 16 Jul 2019
AN5200 Getting started with STM32H7 Series SDMMC host controller
1.0 30 Nov 2018
AN4938 Getting started with STM32H74xI/G and STM32H75xI/G hardware development
5.0 21 Jan 2020
AN4990 Getting started with sigma-delta digital interface on applicable STM32 microcontrollers
1.0 05 Apr 2018
AN5354 Getting started with the STM32H7 Series MCU 16-bit ADC
1.0 23 Mar 2020
AN4539 HRTIM cookbook
4.0 23 Apr 2021
AN4750 Handling of soft errors in STM32 applications
2.1 11 Jul 2017
AN4996 Hardware JPEG codec peripheral in STM32F76/77xxx and STM32H743/53/45/55/47/57/50/A3/B3/B0xx microcontrollers
3.0 24 Dec 2019
AN4803 High-speed SI simulations using IBIS and board-level simulations using HyperLynx® SI on STM32 MCUs and MPUs
2.0 06 Sep 2019
AN2834 How to get the best ADC accuracy in STM32 microcontrollers
7.0 01 Jun 2021
AN4229 How to implement a vocoder solution using STM32 microcontrollers
1.2 20 Apr 2020
AN4221 I2C protocol used in the STM32 bootloader
10.0 11 Jun 2021
AN5027 Interfacing PDM digital microphones using STM32 MCUs and MPUs
2.0 17 Jul 2019
AN5156 Introduction to STM32 microcontrollers security
6.0 06 Jul 2021
AN4861 LCD-TFT display controller (LTDC) on STM32 MCUs
3.0 15 Jul 2020
AN4839 Level 1 cache on STM32F7 Series and STM32H7 Series
2.0 07 Mar 2018
AN4838 Managing memory protection unit in STM32 MCUs
5.0 20 Sep 2021
AN5312 Migration from RevY to RevV for STM32H743/753 and STM32H750 Value line microcontrollers
1.0 05 Apr 2019
AN5293 Migration guide from STM32F7 Series and STM32H743/753 line, to STM32H7A3/7B3 and STM32H7B0 Value line devices
5.0 12 Oct 2020
AN4936 Migration of microcontroller applications from STM32F7 Series to STM32H743/753 line
2.0 15 Sep 2020
AN4635 Minimization of power consumption using LPUART for STM32 microcontrollers
5.0 28 Nov 2019
AN2867 Oscillator design guide for STM8AF/AL/S, STM32 MCUs and MPUs
15.0 07 Oct 2021
AN4760 Quad-SPI interface on STM32 microcontrollers and microprocessors
4.0 13 Dec 2021
AN5073 Receiving S/PDIF audio stream with the STM32F4/F7/H7 Series
2.0 28 Jun 2018
AN4286 SPI protocol used in the STM32 bootloader
10.0 11 Jun 2021
AN5224 STM32 DMAMUX: the DMA request router
4.0 09 Jun 2020
AN4908 STM32 USART automatic baud rate detection
2.0 15 Oct 2020
AN4013 STM32 cross-series timer overview
9.0 01 Jun 2021
AN4899 STM32 microcontroller GPIO configuration for hardware settings and low-power consumption
2.0 12 Aug 2021
AN4989 STM32 microcontroller debug toolbox
3.0 28 Jan 2021
AN4230 STM32 microcontroller random number generation validation using the NIST statistical test suite
6.0 18 Aug 2020
AN2606 STM32 microcontroller system memory boot mode
51.0 26 Oct 2021
AN5033 STM32Cube MCU Package examples for STM32H7 Series
7.0 30 Jun 2020
AN5337 STM32H7 Series lifetime estimates
2.0 21 Jul 2020
AN2639 Soldering recommendations and package information for Lead-free ECOPACK MCUs and MPUs
7.0 11 Oct 2019
AN5036 Thermal management guidelines for STM32 applications
3.0 23 Apr 2019
AN3155 USART protocol used in the STM32 bootloader
14.1 11 Jun 2021
AN3156 USB DFU protocol used in the STM32 bootloader
12.1 08 Jun 2021
AN5225 USB Type-C Power Delivery using STM32 MCUs and MPUs
5.0 13 Oct 2021
AN4879 USB hardware and PCB guidelines using STM32 MCUs
4.0 19 Dec 2018
AN4759 Using the hardware real-time clock (RTC) and the tamper management unit (TAMP) with STM32 microcontrollers
7.0 21 Sep 2021
AN5690 VREFBUF peripheral applications and trimming technique
2.0 09 Dec 2021
AN4655 Virtually increasing the number of serial communication peripherals in STM32 applications
1.1 11 Jul 2017
2022-01-06 7:34 AM
It's under "Application Notes for related Tools & Software (30 of 30)".
However, depending on what buttons you click and how the website feels at the current moment, it may or may not be available with a "Load more" button.
2022-01-06 7:38 AM
Thanks, Jan,
Now it gets really mysterious, because I had definitely seen the AN4891 with my own eyes in this list yesterday - most strange.
Funnily enough, it shows up in the tab Tools & Software, under
MCU & MPU Embedded Software > X-CUBE-PERF-H7.
In X-CUBE-PERF-H7 it is then finally also to be found. Perhaps a little unfortunate positioned.
/Peter
@Community member
2022-01-06 8:13 AM
Indeed. What an inappropriate place.
The whole design of those product folders is a fail. "Modern and trendy", but not functional. ST won't listen to us anyway, I gave up.
2022-01-06 8:20 AM
Peter,
That's not "little". It completely defeats the point of the AN. If it's hidden at an unexpected place, it's as good as it never existed.
Jan
@Peter BENSCH
2022-01-06 8:27 AM
2022-01-06 9:22 AM
Jan,
I agree with you guys completely.
However, with this discussion we have left the original question or the topic of the TO again, haven't we?
/Peter
@Community member
