Are there resources for converting from using the evaluation board to a breadboard setup?
SGold.3
Specifically using the timers on STM32H743XI-EVAL and have the microcontroller STM32H743
What kind of resources would you need, the code should copy-n-paste? Clone existing projects, change pins, merge other code/functionality.
Couple of different breakout boards with the H743 or close equivalent, WeAct Studio, MCUDEV DevEBox, and NUCLEO's
Breadboards not particularly good for high frequency / high density parts.
SGold.3
Thanks, I think these development boards might also be a solution but I was referring to what resistors or capacitors I would need if I wanted to print my own PCB board.
