2024-02-12 08:51 PM
I'm looking at https://www.st.com/resource/en/application_note/an4187-using-the-crc-peripheral-on-stm32-microcontrollers-stmicroelectronics.pdf. It says:
Two examples are described, with the measurement of execution time:
• CRC_usage example: how to configure the CRC using the CPU as data transfer
controller.
• CRC_DMA example: how to use the DMA as CRC data transfer controller.
Where can I find that CRC_DMA example?
2024-02-12 09:21 PM
Hello @CKugl.1
You can find both examples on this link.
Best Regards.
STTwo-32
2024-02-12 09:21 PM
Hello @CKugl.1
Best Regards.
STTwo-32
