ADC VEREFINT Calibration value and VREFINT_DATA of STM32L100RBT6
‎2020-12-14 7:11 AM
I want to use the VEREFINT to get the voltage of my battery.
According to the formula provided by the datasheet (screenshot attached), I need the VREFINT calibration value and the VREFINT_DATA.
What is the register to read the calibration value from? I didn't find this in the datasheet.
The same for the VREFINT_DATA. For the VREFINT_DATA I think it's stored in the specific data address VREFINT_Factory_CONV byte but I do not find in the datasheet what this address is.
ADC
STM32L1 Series
‎2020-12-14 10:25 AM
Please don't be confused by datasheets and reference manuals, you are currently referring to the RM0038, section 12.12 (pg. 287 in rev 16).
According the datasheet of the STM32L100RBT6-A, section 6.3.3, VREFINT_CAL can be obtained from 0x1FF80078...0x1FF80079.
A supply-relative ADC measurement always requires two measurements:
- the signal to be measured relative to the supply voltage and
- a reference voltage, e.g. the internal, also relative to the supply voltage
RM0038 says that VREFINT_DATA is the actual VREFINT output value converted by the ADC. In this case this is the second measurement mentioned above.
/Peter
/Peter
