2017-05-01 2:05 PM
I'm currently trying to use ADC1 + DMA1 + TIM1 on STM32F091CC. I've run into two problems:
1 - DMA is not incrementing the memory buffer('Increment Address' is checked on CubeMX and hdma_adc.Init.MemInc = DMA_MINC_ENABLE). It overwrites every data read on the same address.
2 - Regardless of Data_Width value, DMA is only copying the first byte to the destination address.(overwriting previous values - see 1 and attached pictures).
Generated ADC code:
* File Name : ADC.c
* Description : This file provides code for the configuration
* of the ADC instances.
* Copyright (c) 2017 STMicroelectronics International N.V.
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted, provided that the following conditions are met:
* 1. Redistribution of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of other
* contributors to this software may be used to endorse or promote products
* derived from this software without specific written permission.
* 4. This software, including modifications and/or derivative works of this
* software, must execute solely and exclusively on microcontroller or
* microprocessor devices manufactured by or for STMicroelectronics.
* 5. Redistribution and use of this software other than as permitted under
* this license is void and will automatically terminate your rights under
* this license.
* THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS 'AS IS'
* AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
* PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
* RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
* SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA,
* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include 'adc.h'
#include 'gpio.h'
#include 'dma.h'
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
ADC_HandleTypeDef hadc;
DMA_HandleTypeDef hdma_adc;
/* ADC init function */
void MX_ADC_Init(void)
ADC_ChannelConfTypeDef sConfig;
/**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc.Instance = ADC1;
hadc.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV1;
hadc.Init.Resolution = ADC_RESOLUTION_12B;
hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc.Init.ScanConvMode = ADC_SCAN_DIRECTION_FORWARD;
hadc.Init.EOCSelection = ADC_EOC_SINGLE_SEQ_CONV;
hadc.Init.LowPowerAutoWait = DISABLE;
hadc.Init.LowPowerAutoPowerOff = DISABLE;
hadc.Init.ContinuousConvMode = DISABLE;
hadc.Init.DiscontinuousConvMode = DISABLE;
hadc.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_TRGO;
hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
hadc.Init.DMAContinuousRequests = DISABLE;
hadc.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
if (HAL_ADC_Init(&hadc) != HAL_OK)
Error_Handler();
/**Configure for the selected ADC regular channel to be converted.
sConfig.Channel = ADC_CHANNEL_5;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_VBAT;
Error_Handler();
void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
GPIO_InitTypeDef GPIO_InitStruct;
if(adcHandle->Instance==ADC1)
/* USER CODE BEGIN ADC1_MspInit 0 */
/* USER CODE END ADC1_MspInit 0 */
/* Peripheral clock enable */
__HAL_RCC_ADC1_CLK_ENABLE();
/**ADC GPIO Configuration
PA5 ------> ADC_IN5
PA6 ------> ADC_IN6
GPIO_InitStruct.Pin = AUDIO_ENVELOPE_IN_Pin|AUDIO_RAW_IN_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_ANALOG;
/* Peripheral DMA init*/
hdma_adc.Instance = DMA1_Channel1;
hdma_adc.Init.Direction = DMA_PERIPH_TO_MEMORY;
hdma_adc.Init.PeriphInc = DMA_PINC_DISABLE;
hdma_adc.Init.MemInc = DMA_MINC_ENABLE;
hdma_adc.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
hdma_adc.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
hdma_adc.Init.Mode = DMA_NORMAL;
hdma_adc.Init.Priority = DMA_PRIORITY_MEDIUM;
if (HAL_DMA_Init(&hdma_adc) != HAL_OK)
Error_Handler();
__HAL_DMA1_REMAP(HAL_DMA1_CH1_ADC);
__HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc);
/* USER CODE BEGIN ADC1_MspInit 1 */
/* USER CODE END ADC1_MspInit 1 */
void HAL_ADC_MspDeInit(ADC_HandleTypeDef* adcHandle)
/* USER CODE BEGIN ADC1_MspDeInit 0 */
/* USER CODE END ADC1_MspDeInit 0 */
/* Peripheral clock disable */
__HAL_RCC_ADC1_CLK_DISABLE();
PA5 ------> ADC_IN5
PA6 ------> ADC_IN6
HAL_GPIO_DeInit(GPIOA, AUDIO_ENVELOPE_IN_Pin|AUDIO_RAW_IN_Pin);
/* Peripheral DMA DeInit*/
HAL_DMA_DeInit(adcHandle->DMA_Handle);
/* USER CODE BEGIN ADC1_MspDeInit 1 */
/* USER CODE END ADC1_MspDeInit 1 */
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Calling function:
uint16_t dataBuffer[2000] =
{ 0 };
bool helperFlag = false;
int main()
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_ADC_Init();
MX_USART1_UART_Init();
SB_PowerAudioEnable();
HAL_UART_Transmit(&huart1, 'TEST AUDIO - START\n', 19, 50);
MX_DMA_Init();
MX_TIM1_Init();
SB_Test_Audio_RawChannel_4khz();
while (1)
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
helperFlag = true;
uint8_t SB_Test_Audio_RawChannel_4khz()
uint8_t asd = 0;
HAL_ADC_Start_DMA(&hadc, (uint32_t *) dataBuffer, 30);
HAL_TIM_Base_Start(&htim1);
while (helperFlag == false)
asd++;
HAL_TIM_Base_Stop(&htim1);
HAL_ADC_Stop_DMA(&hadc);
return HAL_OK;
Has anyone dealt with something similar before?
Marcel
#dma #adc2024-06-21 8:09 AM - edited 2024-06-21 10:01 AM
This was fixed twice (because it came back once). It seems to have been resolved conclusively with CubeMX V6.6.0.
Note that old ioc file need to be fixed manually - it is not enough to upgrade CubeMX/CubeIDE.
Guru Jan made a comprehensive post collecting together the storm of threads opened by folks injured by this
CubeMX: ADC and DMA initialized in the wrong order
The wiki also details how to manually update the call order:
MX_DMA_Init order in the main.c file generated by STM32CubeMX, How to fix?
and another helpful post about this is
Stm32cubemx Tips & Tricks: How To Fix MX_DMA_Init Call Rank In Stm32cubemx Generated Projects
