waclawek.jan
DMA not working in CubeMX generated code - order of initialization
Here is a (possibly incomplete) list of threads affected by this CubeMX issue:
https://community.st.com/s/question/0D50X0000BVnBhASQV/bug-report-dma-and-adc-initialization-order-changed-in-stm32f4-hal-v1241-causing-incorrect-adc-operation
https://community.st.com/s/feed/0D50X0000BZFWRISQ5
https://community.st.com/s/question/0D50X0000BbKaA5SQK/haluarttransmitdma-doesnt
https://community.st.com/s/question/0D50X0000BbMcnpSQC/dma-adc-doesnt-work
https://community.st.com/s/question/0D50X0000BWqGdtSQF/haladcstartdma-init-msp-bug
https://community.st.com/s/question/0D50X0000BcS7tSSQS/stmcubeide-110-cubemx-540-switch-initialization-order
https://community.st.com/s/question/0D50X0000Bfs7MvSQI/stm32f3-adc-with-dma-bug
https://community.st.com/s/question/0D50X0000Bh6PntSQE/bug-mxdmainit-wrongly-placed-by-code-generator-haluarttransmitdma-does-not-work
https://community.st.com/s/question/0D50X0000BiA27LSQS/code-generated-calls-mxdmainit-too-late-after-mxspiinit
https://community.st.com/s/question/0D50X0000BcPXk2SQG/32f746-usart-dma-with-stemwin-not-working
 https://community.st.com/s/question/0D50X0000BmoZgKSQU/simple-uart1-dma-dosent-work-generated-with-latest-stm32cubemx-540-and-stm32f0-1110
This is just in case somebody would like to put up a sticky post with this...
[EDIT] Further development with CubeMX5.5
https://community.st.com/s/question/0D50X0000Bwjgi7SQA/with-stm32cubemx-55-and-stm32h743-the-mxdmainit-function-is-not-called-at-the-right-time
[EDIT] Problem reappeared 6.3.0 https://community.st.com/s/question/0D53W000011uIPgSAM/adc-dmahandle-is-0
[EDIT] Official method to fix the incorrect order, if project was generated in "incorrect" version of CubeMX: https://community.st.com/s/question/0D53W00001EzCmCSAV/mxdmainit-order-in-the-mainc-file-generated-by-stm32cubemx-how-to-fix
waclawek.jan
waclawek.janBest answer
Here is the official method to fix the incorrect order, if project was generated in "incorrect" version of CubeMX:
Amel NASRI
OK Jan, your post is pinned on the top of STM32CubeMX questions, waiting for next release of the tool where a fix will be available :)
To give better visibility on the answered topics, please click on "Best Answer" on the reply which solved your issue or answered your question.
waclawek.jan
Thanks, Amel.
Jan
Amel NASRI
Amel NASRI
Amel NASRI
Amel NASRI
Louis Cloete work
Any place where I can see if this is fixed in the newest CubeMX?
Amel NASRI
Hi @Community member​ ,
Did you downloaded latest CubeMX version (5.6)? The issue is already fixed.
-Amel
Louis Cloete work
Thanks for the reply. I did not download it because of data usage concerns. I'll download it now that I know it is fixed.
For future reference, do you have a place where we can see the status of publicly-reported bugs? It would be very useful.
