Why there is no option about ocp on STEVAL-ESC001V1
TKara.2
I’m working with the STEVAL-ESC001V1 and noticed that there is no overcurrent protection (OCP) feature. How can I enable or implement OCP using firmware version 6.3.0? Are there any specific guidelines or examples to follow?
GMA
Hello @TKara.2,
Thank you for your problem report. You are right, OCP Comparator inputs definitions are missing and OCP feature is then not available. We will start working on a fix and we will come back to you.
In the meantime, you can use X-CUBE-MCSDK version 5.4.8, on which feature is available.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
1 REPLY 1
GMA
Hello @TKara.2,
Best regards.
GMA
