2024-09-21 7:16 PM
I’m working with the STEVAL-ESC001V1 and noticed that there is no overcurrent protection (OCP) feature. How can I enable or implement OCP using firmware version 6.3.0? Are there any specific guidelines or examples to follow?
2024-10-08 4:12 AM
Hello @TKara.2,
Thank you for your problem report. You are right, OCP Comparator inputs definitions are missing and OCP feature is then not available. We will start working on a fix and we will come back to you.
In the meantime, you can use X-CUBE-MCSDK version 5.4.8, on which feature is available.
2024-10-08 4:12 AM
Hello @TKara.2,
