want to check with CTM007V1 instead of CTM006V1
‎2023-09-04 2:30 AM
Hi all,
I'm currently having CTM007V1 driver board for motor control application. the control board is stm302r8 MCU and the driver board is STEVAL - TTM001V1. can i use modify the CTM006V1 firmware and replace it with CTM007V1 firmware?
Regards, Siva.
‎2023-09-14 12:31 AM
Hello SivaVishnu09,
You can compare the schematics of both CTM006V1 and CTM007V1 driver boards on our website to check if there is any major modification that would not allow you to run a CTM006V1 firmware on a CTM007V1 driver board.
Hope this will help,
Gaël A.
Hello SivaVishnu09,
Gaël A.
