I use a STSPIN32F0 Advanced BLDC controller with an embedded STM32 MCU evaluation board. By setting the PF7 and PF6 pins I am able to get the linear regulator voltage to go high. But, When I am trying to toggle the mosfets I am not able to do that.
ppota.1
I wanted to know if there is any enable pin or some code that needs to be followed before toggling the pins that are going to the gate drivers.
GMA
Dear Ppota.1,
Firstly, we would like to sincerely apologize for the delay in replying to your post.
If your point is still pertinent, could you please give us the reference of your EVAL board?
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
