Running the STSW-Robot-1 kit
Luca3
i am trying to run the Evalkit-Robot-1 example project. unfortunately i get the error "configuration files cannot be found in 'MCSDK_v5.4.4/MotorControl'. This version is no longer available for download. Is there an updated version of the example project somewhere that uses a newer sdk?
1 REPLY 1
GMA
Hello @Luca3;
Issue has been reported and new updated version will be provided.
For the moment, could you please use the available provided FW data base?
Compile issue could the generated, check this post for workaround.
If you agree with the answer, please accept it by clicking on 'Accept as solution'.
Best regards.
GMA
